When I was a much younger feller I did a lot of backpacking and some mountaineering, even a lil rock climbing. I wore some higher end boots from a company called Vasque. The use of Sno Seal violated their warranty. Don't know if things have changed or not. I heard it rotted the stitching. But I know that A Alberta Ed has been doing that for a long time.
I'm not sure what it is but there has to be something to soften the bees wax because bees wax is quite hard otherwise and SnoSeal is soft right from the can.Sno-Seal has a solvent in it that lowers the melting point. It likely doesn't fully evaporate from the warm leather and that might damage the stitching.
I'm a fan of Snoseal
It's the solvent they use.I'm not sure what it is but there has to be something to soften the bees wax because bees wax is quite hard otherwise and SnoSeal is soft right from the can.
I use a homemade concoction because I like making my own stuff. I blend neatsfoot oil with warmed bees wax to a ratio where the beeswax does not cool rock hard. To apply it I warm the homemade "conditioner" with a heat gun to a point where I can spread it. I smear it on the leather, work some into the seams with a toothbrush then warm the leather a bit with the heat gun on low so the conditioner soaks in. Right or wrong, it waterproofs my boots.
There is a subtle, but very important, difference between putting Sno-Seal on leather and then heating it, vs. putting it on leather that is already warm. Solvents evaporate toward a source of heat. So if Sno-Seal is applied and then heated, most of the solvent evaporates toward the hair dryer leaving the wax on top of the leather. On preheated boots, the solvent evaporates into the warm leather drawing the wax in with it.
