I think it is Burl. I'd always assumed it was anyway. You gotta have good wood, makes the difference. Funny thing is, it just sits in my safe. I discovered Beckers two weeks after I got the Condor.
No trouble at all on this one. This one I did like I've done a buncha times before. Clamp on one scale, drill two holes, move clamp, drill last hole. Repeat same process for other side. Pin both scales together minus blade, sand the top portion of the wood, where you'd not be able to get to it later. Degrease the metal on the handle, groove out the underside of the wood, lightly dampen metal, add gorilla glue to both sides. Drive in the pins and clamp for 2 hours. Its easy to keep the pins aligned cause im cutting the wood overly large doing all of the above then when the glue is dry, I'll work the wood to shape and thin.
I think it's much harder if one is using screws for removable scales. I'm doing my first one of those now and it's a bitch. Though I'm learning all sorts of new tricks to fix my mistakes.
