I just received a Condor "sharpfinger". I like the design alot. The leather sheath it came with is of very good quality. The knife looks good and feels great in the hand. It seems to be a bit thick for a good skinner considering its diminutive length, but I guess that should add to its robustness in case it is tasked with harder chores than just slicing. It is made of 420 high carbon stainless, which I am hoping is great for ease of care, or perhaps I should say in case of neglect. The thick blade goes from a full flat grind from the spine for about 2/3 the width of the blade transitioning to what I guess is a convex grind for remaining 1/3 of the blade to the edge. This is where the problem comes in. The secondary grinds are way off in relation to each other and the edge is fairly blunt. It has more of an edge meant for a cleaver (probably aroound 30 degress either side or 60 degrees inclusinve) that would be hard to try and skin anything with. I began trying to correct this with a wicked edge sharpener that holds the flats of the blade perpendicular and this is what led me to consider it a bad grind from the factory. The scratched area indicating where the stone comes into contact with the blade is twice as wide on one side when compared to the other, which seems to be indicative of the geometry of the secondary grind that makes up the final edge being off by a substantial margin, considering that the sharpener should be holding the flats perfectly perpendicular. I can say that the 420hc ss seems to be hardened well, as it is taking a long time to hand grind a new edge, even with coarse diamond hones on the wicked edge.
