Consensus on how thin behind edge and degrees per side for "woods knife."
HPD
I've been goofing around and made a knife I call the "Chungus" (my 10-year-old son thinks that's hilarious). For the heck of it I made the thing pretty thin behind the edge - .008-.010 measured with my calipers - and the angle according to the DMT chart I have is supposedly about 16 degrees inclusive (I had to interpolate). I know that's not an exact angle measurement, but it's pretty acute. The steel is AEB-L. I took a Douglas Fir 2x4, made some feather sticks, did some twist cuts and some notches. When I went to chop with it it performed well until I decided to chop and twist out a knot. I got some minor rolling on the edge in one small area that was pretty easy to remove, and other than that I was still able to shave hair and cut notebook paper on the undamaged portions of the knife. So overall I'm pleased, but because I would like to regularly use this knife about as hard as I did during the test, I'd like to know what angle to select and how thin behind the edge I should go. I know there are a lot of factors, but assume a decent heat treatment.
Since I make mostly slicing knives, I guess I have a different idea of thickness. If I made a knife that was .065" 1/4" from the edge it wouldn't cut much of anything in a kitchen. Maybe a camp knife chopper would be OK at that thickness.
All this goes to prove that most specs like BTE and edge angles are only useful in respect to the actual knife use and blade geometry.
One thing I can recommend if you want to know if you are getting your knives sharp is a BESS tester. Ther basic PT50C model is all you need for our purposes. Get a LOT of test clips, you will find you go through them pretty fast once you start testing edges.
Here is some good resource info on edges:
There are whole forums just on edges and sharpness. The BESS Exchange is one with many sub-sites that may interest you folks.
Thin Wins....Haha..thick edges/blades are for Chumps.
;P
My last Busse/SYKCO/same thing blade was .065"bte
Ugh!
It's a SLAB
I like my knives WAY Thinner.
I do too, which is why I figured I'd make the edge on the thin side just to see what would happen. I'll probably end up taking it back to .015 BTE and 20-something degrees. I was just curious what other people do with their "woods" knifes.
Thanks.
i like to keep it .01 behind the edge but let the tbe get thicker towards the tip....more like .03 to .06 at the tip so you can do more bushcrafty stuff but also slice the heck out of stuff with the main portion of the blade.
Agreed, I do the same. The tips won't survive if it gets too thin and acutely edged.
The distal taper makes it already very thin.
I also raise the edge angle as I approach the tip on very thin and low angle slicers. I might be at 10° and lift the spine during the last inch or two to 15°.
I never concern myself with the BTE thickness because I flat grind to a zero or near zero edge. It will cut you if you aren't careful when the bevels are ground. I leave most blades at a 400 grit finish, and some even at 220. I add the edge angle from there.
On a FFG, BTE is whatever the spine thickness and the blade bevel height is. It cannot be changed unless you grind the edge back from the apex. You could calculate it easily if it really made any difference. Example: A zero edge blade with a spine .10 thick and a 1.5" bevel height has a roughly 4° edge. If I go back .25" from the edge the thickness is approx. .017". This isn't changed appreciably by sharpening the blade at the final edge angle of 15° to 20°.
The way I do on many/most blades is put the edge on as a convex on the rotary platen. I use a 220 or 320 grit belt running slow and follow with a fresh 400 grit belt. I then buff off the wire with matchless white polish in about two passes per side on the buffer. I clear the final wire with ten cuts through cardstock. This leaves a very sharp and aggressive cutting blade. On super sharp slicer blades I follow the belt with a charged leather strop instead of the buffer. I use yellow rouge on the strop.
  • Like
Reactions: HPD
I too would like to make a bushcraft from AEB-L. It's stainless and supposedly tough. However, ....
I've tried 4 different heat treating recipes, different hardnesses (58 to 62), various edge geometries, then doing destruction tests. I'm not impressed. Edge chips and snapped tips all over the shop floor.
I even went as soft as 1925f austentizing temp and tempered back to 58. That was a fail.
I have no trouble creating durable MagnaCut and 26c3 blades. I thought AEB-L was supposed to be tougher than either of those.
That's interesting. Were the blades In MC and 26c3 approximately same geometry and purpose?
Do you wet grind ?
The tests would only indicate if AEB-L was better or worse than 26C3/Magnacut if the tests were done side-by-side with identical blades. Testing one metal only with the tests you described does not show anything except that you exceeded the physical limits of the steel and geometry. Testing for Carta and other repeatable and measurable tests will tell you something. Also, HT and manufacturing procedures would have to be the same for the tests to be comparative.
AEB-L is about twice as tough as 26c3 and Magnacut.
Yeah. Exactly. That's why I am so surprised. I'm totally blaming myself.
It started when I was destruction testing a couple of drop point hunters in 26c3. They had identical heat treats and grinds. The tip on the first one snapped off pretty easily prying into wood. So I bent it further down until it snapped. Grain looked OK. So I did a third temper on the second blade at 450f. As predicted by Larrin, the hardness dropped one point to 61hrc. That blade became indestructible!! I could pry wood all day with it.
Back to the OT.
I figured I could make a great woods knife in AEB-L. So far I'm failing.
ferider ferider yeah, I do wet grind. But there's still a chance I burned something.
Stacy. You're absolutely right. I wasn't setting out to make a comparison study. So the blades aren't identical. I really don't believe AEB-L is less tough. There has to be something wrong with my process.
FredyCro FredyCro The AEB-L blades were hollow ground and the others flat. But thicknesses were similar.
I think I'll make a few more in AEB-L that exactly match a MagnaCut test blade. The blade hardness isn't a consideration at this point. First, get the performance I want. Then push the hardness.
There has to be a geometry/heat treat combo for AEB-L that would make a great bushcraft.
I like…
Bushcrafty knives .014-.016
Field dress/edc around .01” or less
Kitchen as thin as I can really
I’ve found both aebl (and 14c28n), magnacut, 52100 to handle it very well
Nice looking blade.
Woods blades can definitely be made too thin. If your primary use is cutting meat, hide, and food, a very thin edge with an obtuse 30+total angle edge will work fine. If you cut and carve wood, a lower edge angle with a taller bevel with the attendant thicker edge will often work better.
I have had some chopping blades with what was probably a high 30 to low 40 degree total included edge, and they were far too ready to glance off wood when I was trying to do controlled crafting work.
The majority of what I have made would be classed as woods-knives, mostly in the 3.5 - 5" range. When I started I didn't have a grinder and pre-HT edge thickness (home heat treated carbon tool steel) tended to be 0.75mm. Sharpening/grinding on a 220grit water stone by hand created a convex bevel that had a total included angle in the mid-20 degrees, but was quite tall before transitioning to the primary grind. This grind actually worked rather well in the woods and for related tasks. It wasn't used much for game prep, but did a lot of wood work and a reasonable amount of food prep.
Measuring such a knife I have here shows a 2mm (0.079") tall bevel going to 0.67mm (0.0264") at the transition. This is a mild convex, so a little more at the edge than the 20deg total included you would get with a flat bevel. It carves/feathers wood great.
Following much reading on this forum, particularly the posts that Stacey has made about edge thickness, I made an AEBL blade with 0.45mm (0.0177") at 2mm tall. This is sharpened at my customary angle with a convex edge. Cuts meat very well, great in the kitchen, sharp as hell....but rather disappointing for a woods knife. It really doesn't run long shavings well at all. A tall bevel contributes to control when trying to run a long shaving, as in making feather sticks, or trying to craft something, be it a spoon or a canoe paddle. This otherwise beautiful AEBL blade just lacks stability in a long cut.
On a wood chopping blade, you don't want the blade to over penetrate and bind in a cut, so again, a bit of thickness not too far back from the edge can be helpful. I would probably keep the same angle, but make the bevel a little taller before starting the primary grind. This isn't so much about steel strength, but about blade height and length increasing instability and trying to offset this with a taller bevel.
All the best
Chris
