Construction and/or Electrical Stuff
batosai117
Feedback: +104 / =0 / -0
Hello there,
Julian from J's Knives-N-More here with some goodies courtesy of my father. He's been in the electrical business as long as I've been around, and we have 2 or 3 goodies up for sale here that have accumulated over the years:
1. Greenlee Crimper Cutter ECCX12-12V Gator Pro
Nickel-metal hydride battery (Ni-MH) delivers up to 140 cycles per charge.
360° rotating head adjusts to your work position.
Lightweight, plus ergonomic-angled handle for comfortable, low-stress use.
Cycles in seconds with two-speed hydraulic pump, maximizing productivity.
Automatic retraction when crimping and cutting cycles are complete.
Uses all optional CCX blades and adapters (see page 145).
Includes two batteries, a choice of either a 120V, 12V or 230V one-hour charger, and a high-impact molded carrying case.
Crimping Force 24,000 lb. (107 kN)
Length 14-3/4" (375 mm)
Height 12-1/8" (308 mm)
Weight 10.5 lbs. (4.8 kg)
Battery 12 Volt, 2.2 Ah,
Ni-MH Battery Charge Time 1 hour
UPC No.: 07028 07029 07030
Cat No.: ECCX12
Brand: Greenlee
In Addition to this, there will be a full set of bits plus a size 8 that was purchased seperately but never used. This is brand spanking new, it was never used and was only opened up for pics and satisfaction of owning it :o
Going for: $2800.00 Shipped Overnight with Insurance and Signature Delivery. Hell, if you live close enough I'd rather hand deliver such a valuable item :foot:
2. Reed LM-81LX Light Meter - Portable
Reed Instruments LM-81LX Light Meter Features:
• Designed for one-hand operation and to fit easily into a tool belt or pocket
• Auto-Ranging • User selectable Lux/Footcandles
• Min/Max and Data hold functions
• Auto shut off and zero adjustment button
• Over range and low battery indication Battery included
Ranges: 0 to 20,000 lux; 0 to 2,000 Fc Resolution: 1, 10 lux; 0.1, 1 Fc Accuracy: plus or minus 5% of reading Sampling Time: 1 time/second Power Supply: 1 x 9V battery (included) Dimensions: 6 x 2.4 x 1.3” (154 x 60 x 33 mm) Weight: 5.6 oz (160 g)
This is New In Box, was only taken out for pictures. We had a few of these laying around and decided that someone else would be able to put it to use.
Going for: $70 Shipped via USPS Priority 2-3 day delivery with insurance and delivery confirmation.
3. BRADY ID PRO PLUS LABEL MAKER
The ID PRO Plus from Brady is the smallest, most affordable method available to print wire, outlet, face plate and component labels on site and on demand. Designed for versatility as well as portability, it can accommodate three different materials widths from 0.59 in to 1.59 in. The self-adjusting printhead accepts a wide variety of labeling materials including self-laminating and vinyl cloth, plus BradySleeve and PermaSleeve heat shrink wire markers. The ID PRO Plus can print practically any wire, outlet, face plate and component marker required, without guesswork. Its LCD display previews the information to be printed. And the palm-sized ID PRO Plus rugged ergonomic design includes shock-absorbing bumpers to protect it from damage in the field.
Key Features
• Rechargeable battery pack
• Easy-load ribbon cartridge
• Prints both labels & sleeves
• Automatic label serialization
• Prints up to eight variable lines of text
• Normal and Bold type available
• Max. label width: 38.10 mm (1.50 in)
• 6 month warranty Specifications
• Weight .73 kg (1.6 lbs.)
• Shuttle head impact printer
• Two type sizes with normal and bold available
• Operating temperature range: 4o C - 49oC (40F to 120 F)
• UL listed battery charger (120 VAC, 60HZ input/9V DC 75 mA output)
• FCC class A approved
• Prints up to 250 labels between battery charges
• 6 month warranty
This particular Labeler is new and has never been used. It just does not come with the box. It does, however, come with an extra battery (also new).
Going for: $140 shipped via USPS Priority 2-3 day delivery with insurance and delivery confirmation.
I can be reached around the clock at: jsknivesnmore@gmail.com
Paypal address is: batosai117@yahoo.com
