- Jul 28, 2006
Stacy, which HF thermometer are you using? I didn't think the $15 would read up to forging temps. Thanks in advance, you may be saving me some moneys
Stacy, Did you ever try hitting the blade with your laser IR pyrometer immediately after pulling it out of the forge? Wouldn't the IR unit work effectively then? I mean, say you're going to oil quench W2. You're losing a second or two from the time that you remove the blade from the forge and put it into the oil, right? So, wouldn't the same line of reasoning hold for getting a temp right off the blade immediately after pulling it from the forge?
Thanks
- Mitch
Taking the temperature of the blade outside the forge will only tell you what temperature it is at that moment. It won't tell you if it has been in a forge that is too hot. The better alternative is to monitor the forge chamber temperature and not let the blade be in an atmosphere that will harm it. It can sit for two minutes or ten, as long as the temperature is no higher than the austinitization target, it won't harm the blade.
Most laser guns won't read accurately aimed at a flame. You can adjust the emissivity setting and compensate for it somewhat, but every time it may be different.
Stacy
