RICKSTER
Platinum Member
- Dec 16, 2002
I had the same problem when I had my 3.5" XM-18. Nothing opens like my 3" XM-18 though. That thing has the smoothest deployment of any knife I know of or have handled except for maybe a RJ.
I took these instruction straight from Hinderer sub-forum on USN.
1. Open blade to 90 degrees and tighten pivot so that it is really tight.
2. Close the blade and loosen frame screws so they arent tight, but still holding the frame together.
3. While the blade is still in the closed position, pull blade towards the side you want the blade to move. In my case, I pulled the blade toward the liner/scale.
4. While pulling blade, tighten the frame screws.
5. Loosen the pivot and adjust it to the desired tension.
I can confirm that this information is 100% accurate and works perfectly. I even tried it several times to confirm that it does indeed work.
I called Rob Orlando at the Hinderer shop and he explained exactly how to center the blade. What is not mentioned in the Hinderer sticky note that BBQ BOY posted is that when you go to tighten the screws on the scales that you START at the bottom screw & work your way toward the PIVOT. This is VERY IMPORTANT because it allows the blade to stay exactly where you have adjusted it to by the turning the pivot screw clockwise or counter clockwise. (To The Right Or Left). Thats my 2 cents worth.................
