A variac, bridge rectifier,a few switches, and a DC voltmeter will get you going for anodizing. Ebay has them all.
A Variac ( variable AC transformer) is also called a powerstat or a variable transformer. You don't need a big high amp unit for anodizing, so there is no need for the $100 units. A $30-60 unit will do fine. I see 1 amp units on Ebay for as low as $20.
Old model RR train controls often have a great variac you can buy for cheap. I bought a box of train controls and RR junk for $25 that had three good powerstats in it.
OT:
Is this thing cool or what!
http://www.ebay.com/itm/VINTAGE-Adj...896627?hash=item238565ccb3:g:WWwAAOSwX61ZKCyp
In my old electric/electronic workshop, I had a giant Variac unit for adjusting the power feed to motors. It was circa 1900. I hauled it out of an old building being torn down in the 60's. In my shop, it was merely a decoration, because the old cotton wrapped wires were so ratty ( literally and figuratively) it would be fireworks if you put power to it. The unit weighed around three hundred pounds and had a foot long crank that drove gears to turn the core. There was a brass dial with 0-100 and a pointer. It took one turn to move the pointer one digit. It had big meters for voltage and amps. On one side was a big rectifier block to make DC. IIRC, it handled 100 amps. There were separate terminals for AC and DC output.
In the early days of electricity, there was AC and DC power (Westinghouse vs Edison), both were generated by local generators ( sometimes several in the same town) and the power feed could vary a lot from place to place. Some cities had both current types on the power poles.Most motors ran on only one or the other, but some smaller motors were "universal" and could run on either. Since the power supply could vary in voltage as well as frequency, motors could run hot and burn out sooner if the power wasn't adjusted. Since most motors had brushes, some could be speed controlled by varying the power, too.
The power room of a machine shop or other place with motors that needed a certain speed had these big variable transformers to adjust the building power to an exact voltage. The person in charge of the power room would adjust it every day as needed.
A guy was visiting my place one day and saw it. He offered me $500 for it ... and I helped him load it in his truck.
