- Feb 28, 2006
Hi Folks,
I'm finally getting around to building a temperature controller. Would you look at my layout plans and give me feedback before I start drilling and cutting the case to mount all the components in?
The fan is at the bottom with the SSR and heat sink mounted above it. I couldn't get the SSR as low as I had planned due to the mounting screws for the composite board the heat sink is mounted to (rather than directly to the back of the metal case). Thus, the fuse and switch are at the bottom of the door to fit in under the SSR as there wasn't enough remaining room to put everything towards the top. I still think the fan should cool the SSR ok though. I'm mounting the fan at the bottom rather than the top as it seems there would be less particulate matter dropping into the case. The PID and bus are at the top mounted to the door.
What say you?
Thanks so much, Phil
What say you?
