Great handiwork, but...... why? How many Moras have failed on the tang for you. I'm no welding genius, but wouldn't the blade to tang transition still be weakest point? Otherwise, I've got 3 different companions and the entire handle would have to shatter as well as the tang to break to have a tang failure, unless it snaps off at the handle/blade connection, which brings me back to my question about the strength about that same point being any stronger.
Never broke a Mora myself.
I actually did use a steel welding rod. The 3 places the tang is attached should be plenty. If I did the entire length of the tang, the HT would be even worse off, right?
Cool to know James!Just because you believe you "can" do something, doesn't mean you "should" do it. I must say, for the amount of effort you've got into this project, you could have ground two full-tang blades from scratch by now and been a lot better off.
If you insist on pursuing this sort of thing, it may be helpful to know that when professional bladesmiths want to extend or build up a tang, they generally employ silver brazing techniques instead of welding, to avoid heat issues.
That's why I'm not planning on using it very hard. I'm saving for an ESEE 6 for hard use. This is more just for fun to see if it can be done (which I think at this point I am comfortable to say it can be done, even if it might not be perfect).
BeckerThat's why I'm not planning on using it very hard. I'm saving for an ESEE 6 for hard use. This is more just for fun to see if it can be done (which I think at this point I am comfortable to say it can be done, even if it might not be perfect).
Like I said, this is just a "trial." I will probably do this again later, building off of what went well/wrong this time. I'm just curious--what wood did you use for your Mora rehandle?
