- Nov 16, 2002
Stay away from the really soft waterstones; they wear faster than S7 steel, which normally is easy to grind.
Making sure I understand correctly .... are you saying that this occurs using a waterstone that's flat, and the slurry produces this slight convexing, or are you using a stone that's dished out somewhat?I have found, much to my delight, that the slight rounding that using a 200 grit waterstone produces just by its wear it pretty much the exact amount of curvature I find optimal for edge bevels....
Try the 220 pink ceramic waterstone from Epicurean Edge or Japan Woodworker. I bought one on the recommendation of yuzuha and HoB because I wasn't satisfied with my Norton 220. The "pink brick" wears slower, cuts faster, and holds water on the surface longer than the Norton. It costs more, but you can get the large size which should last you a pretty long time.Looks like I can buy a Norton 220 grit 8x3x1" waterstone for under $25. Other stones I should consider instead if I decide to give this a try?
... are you using a stone that's dished out somewhat?
The 200 silicon carbide I have wears really fast, as in it will form a visible hollow (mm+) in just one edge regrind, but the speed of cutting is high. Are the lower grit ones actually slower?
