- Oct 18, 2001
Cliff - I do agree with what you're saying.
Just re-read my post above.
This is the same thing as what you described Mel doing to his blades.
I maintain that even with a "lift" at the end of your stroke, you still have a convex edge with no true micro-bevel to it.
The advantage is the same: Final grind angle = wider.
Also, the comment made earlier about blades wearing down over time being a disadvantage to a convex edge is nonsense. That happens with whatever knife you have (excepting those made with 1/16" steel with only a micro-bevel....a rarity). Any blade with any kind of taper to it is going to get thicker, the more material you remove.
Which brings me back to a sub-advantage for the convex edge - by stropping, you are removing less material. Only steeling/burnishing is better. CrOx is 5000 grit, and if you use finer powders, you can get ~10-12,000 grit. One of the great benefits of stropping is the edge-trailing effect. You are massaging the edge back into place....re-aligning it.....rather than removing steel to reform the preset bevel.
There is still a small area similar to a microbevel, but where a microbevel has a sharp turn in angle, the convex edge is smooth = only difference.
