Actually a v grind of comparable angle has MORE steel behind the edge. The "convex has more steel thing" is nonsense. I have a pretty strong suspicion where it originates. Sorry. Geometry doesn't lie.
As far as maintenance...I find they are EASIER to maintain. It takes advantage of not being able to hand hold an exact edge eangle consistently, and can be made/maintained with a few bucks worth of simple materials. Some wet/dry sandpaper, a piece of leather, and a flat surface is really all you need.
what a perfect visual... great job marcinek. i totally agree. so what happens is that you have increased cutting ability (slightly) due to the shoulders being knocked off/rounded.
But, when you compare a convex edge to a V edge and when the shoulder widths of the two edges are the same and when the edge heights are the same, under those conditions a V edge will be more acute and a convex edge will be more robust.
A convex edge doesn't have an angle; it has two intersecting arcs.
The red line it tangent to the blue curve at point A.
Imagine you draw a vertical line though A and reflect the blue curve and red line across that vertical line.
Then you have a vee grind (the red lines) and a convex grind (the blue curves) that have the same edge angle. And the convex is inside the vee. And thinner.
I totally get that a convex edge has no actual bevels to it like a V Grind, i guess I just want to know much other stuff about it such as will it keep a keen edge just as long or longer than other ginds, specifically speaking about bark river here with their A2 steel as on the Ghost 2. Does anyone own a Ghost 2? Would love to hear more about convex grinds
Marcinek your point about geometry is well taken but the more apt comparison might be between a convex and hollow grind, the hollow grind being so common.
Marcinek,
Thanks for the illustration. That is probably a good representation of most convex edges, especially since many people convert their V edges to a convex one. It isn't representative of all blades and sharpening angles though, so you have only shown that you CANNOT make a definitive statement about whether convex/flat edges have more mass behind the edge. I think that is the point some are trying communicate.
You can't argue with geometry.
