You're using a method of calculating the angle of a triangle here. You can't describe the arc in that way. You have to use the tangents to describe the edge angle like Marcinek was saying(thanks Marcinek. It's been about 20 years since I had to do any of these calculations. I couldn't pull the word 'tangent' out if my life had depended on it.) Further, the picture on the left clearly illustrates a more obtuse convex grind at the apex when compared to the v. In order to have the arcs outside of the v, you made the initial angle at the apex larger on the convex.
Yes, when the height and width of the edge is held constant, the V edge will be more acute and the convex edge will have more steel behind the apex. That is what I keep saying.
You can change those characteristics by changing the height or width of the edge in ways that can make the V edge more or less acute than a convex edge and more or less robust than a convex edge. So, for example, in the drawing on the right, the convex edge an be made more acute than a V edge by making the edge height of the convex edge taller than the edge of the V edge. I could also take that new convex edge and convert it to a V edge that is more acute than the convex edge.
What Marcinek is saying -- or repeating -- is not correct. It is not true that a convex edge has less steel behind the edge than a V edge. It may or may not, depending on the geometry.
You can't directly compare angles of V edges to the acuteness of convex edges because convex edges are not straight angles. The acuteness of V edges and convex edges is measured differently. The acuteness of a convex edge is not constant -- it varies. And with obtuse convex edges, the acuteness is considerably different (more acute) near the shoulders than it is near the apex. That variation in acuteness does not apply to a V edge, unless you are adding a micro-bevel.
That apples-to-oranges comparison is what 42 gets wrong. He's trying to compare straight angles on a V edge to the acuteness of a convex edge, assuming that the convex edge is measured the same. They are not measured the same. Mixing geometry in that manner is like dividing by 0 to get any kind of mathematical answer you want.
The truth is that convex edges and V edges come in an infinite number of variations. For any given knife doing any given task, there will be little to no performance difference between an optimized convex edge and an optimized V edge.
All this talk about the magic of convex edges is smoke and mirrors. Both V edges and convex edges can do anything you want.
