If I want to do some wood work, I will sometimes dig the Companion out of my pack, but nine times out of ten I'll just grab my Fallkniven F1 and do whatever needs doing.....The Mora is more often than not just a spare knife in case something happens to my F1.....
I use sandpaper on a stiff mouse pad for my convex sharpening. No problems thus far.''ed: I strop on cardboard to try and keep 'em sharp.
Howdy!
I use a strop most of the time to keep my F1's sharp. If they get too dull for that, I will give them a few light passes on white ceramic rods @ 17 degrees and then strop. If I need to repair edge damage, re-profile or sharpen one that has really gotten dull, I use sandpaper(400 grit to start) backed by a hard block type leather strop, then a few strokes on the ceramic rods and finally stropping on a slack strop.
Interesting. What angle do you hold the F1 to strop?
I've favored scandi grinds for ease of freehand sharpening, but maybe I need to stop fearing the strop.
Just lay the knife flat on the strop and then lift the spine until the edge touches leather, then draw backward (away from edge) using only light pressure.
Stropping can be a bit intimidating if you've never done it, but once you actually try it you'll find that it is actually quite easy. FWIW, I also strop my scandis. Stropping adds a new level of "bite" to any edge regardless of how fine of a stone or sandpaper you've used to sharpen the knife.
Do a Google search on "Brommeland Gunleather Strops". You'll find them at most places that sell knives. I cannot recommend them highly enough![]()
Depends. There's a huge difference between a sub 3/32 inch carbon mora and 1/8 inch thick plus scandi. IMO the thick scandis are garbage but the mora is great.
My preference is for a thin scandi but only because it takes less concentration to get them screaming sharp. If I want a more stout knife I'll choose flat,saber or convex. All good if done right.
I carry a Fallkniven F1, a Companion carbon and a folding Silky saw.
