convex?
I have reconditioned convex edges in the field with a stone and a strop/belt without any problems at all for decades now. It is my favorite edge profile and I use it on all my knives.
also, if I may throw in my own question....can you take a traditionally ground knife, and put a convex grind on it using the methods used for sharpening a convex edge, with a more aggressive grit? ....if that makes any sense....
Here is my FH9 that I did exactly that, re-profiled the beveled edge and convexed it. Took about 45 - 50 minutes starting with 220 grit sandpaper and a mousepad and working my way up to 1500 grit (220 - 320 - 400 - 600 - 1500) NOTE: 3G is hard steel, about 62HRC, softer steels would profile in less time.
Then I finished with a few passes on a strop.
Hope you can see the difference OK in the photos.
Beveled (before)
Convexed (after)
Kevin
I wonder if field maintenance isn't a moot point to some degree? Granted, I'm rarely out in the wilds for more than 3-4 days but I can't recall ever dulling a knife so much that it was appreciably harder to use.
Is field maintenance a big issue with quality knives?
im a soldier its more a worst case scenario type of question ive only chipped the edges of folders in the woods never afixed blade.
