Exactly the same process as convexing anything else, from a knife blade to a piece of wood or plastic---grind a curve. This can be helped out with a slack belt, but can be done on a flat platen by making several, small flat bevels at graduated angles and then rounding off their shoulders to make one smooth transition across all the planes. For that matter, you can do the same thing and convex a blade with any stone or metal sharpener, though your progress will be much slower, of course. Wet/dry sandpaper on a mousepad, sanding block, or thick piece of leather is a tried-and-true technique too, though it also requires a good bit of time.
You have to decide just "how convex" you want things to be---meaning do you want a uniform, continuous curve throughout the whole width of the blade resulting in a very thin edge, or an gradual one up top with more extreme curvature down near the edge which will more closely approximate the cutting characteristics and edge strength of the factory grind?
The two most important things are to not get in a hurry, and to protect your heat treat. The latter is only an issue if you are using power tools, of course, but a very important one. All that follows assumes that you're going the power tool route:
I do not let a belt linger on any part of an already heat treated blade for longer than a second (or one and a half) at a time--meaning that I'm pulling the blade horizontally across the belt at a rate where the width of the belt is the distance the blade moves across in 1 to 1.5 seconds. So, on a 1" belt, it would take me three to five seconds to pull the entire length of a BK2's blade across the belt. Obviously, I'm rocking faster on a 2" belt than a 1", but that's okay as just as much steel is being removed. Anyway, I usually do a few (3 to 5) passes like this and then dunk the blade in a room temperature bucket of water for a few seconds, dry it off, and go again. The thinner the knife (and the thinner your edge gets as you go) the more careful you need to be about over-heating it. Use new belts, and when one obviously starts slowing down in its cutting, chuck it and move on to another, as belts just run hotter and hotter the duller they get.
My last advice to you is what I always tell people---don't perform your first mods on a knife you like. I learned grinding on a sack full of $5 chinese machetes that I bought from a hardware store. I say "learned" though I'm certainly not the equal of most of the honest-to-goodness knifemakers on these boards. Still, I'm a hell of a lot better than I was, way back when. Now, if you want to practice on something that's closer in size and thickness to your Becker, you can buy something like this for example:
http://www.knifecenter.com/kc_new/store_detail.html?s=UC947CSNB
There's three knives in that pack, working out to about $10 a piece once you've shipped 'em. Of course, they'd be changing a hollow to convex versus flat to convex, so you also might look at something like this as being--in terms a grinds--a closer approximation to what you intend to do.
http://www.knifecenter.com/kc_new/store_detail.html?s=CN23243HC
Best of luck, don't get discouraged by inevitable screwups, DO remember that almost any screwup is correctable, and
protect that heat treat!
