Convexing in the field w/o sandpaper?
I recently saw a thread here w/ pics of convexing a blade w/ a diamond rod. I've been trying it both on small fixed blades and some machetes, but can't seem to get it as sharp as I want. Any tips from folks that have more experience w/ it than me?
I use the Field Strop from JRE ($10).
http://www.jreindustries.com/fieldstrop.htm
picture.php
picture.php
A piece of W/D paper doesn't take up much room and weighs nothing. No reason not to have some with you. For touching up, which is all a properly sharpened convexed blade will need over a couple of week period with normal use, you can strop the knife on your belt, or even your pants leg.
If you are having problems getting the knife sharp, you might be applying too much pressure during the sharpening process.
If all you have with you in the field, is a stone of some sort, or it's all you can find, i'd suggest trying to put on a micro-bevel on your blade, as that doesn't change much in terms of edge geometry, and leave the convex sharpening to when you get back to your "proper" supplies.
Also, if you're not able to get your blade sharp, you might be using too much pressure, too coarse a grit, or the wrong angle. Or all three.
My 2 cents, as always YMMV.
Me neither. I believe I'm fairly good at sharpening but I can't get anything like the results I'm accustomed to by using rods or steels especially if they are both waving around like a chef trying to score on a scratchy edge. There's just no way to get the control required.
Try laying your rod flat on something and swiping very gently across it like you are using a stone. If you put a thick stripe of magic marker pen along the cutting edge you'll soon see a scratch pattern of where you are hitting. I've got to say though that steel, diamond, or ceramic rods aren't my preferred method by a good margin.
The roll up strop from JRE is on my wish list, I have been meaning to buy one for weeks. Right next to that on my list is a Badger firesteel from goinggear.com
I am seriously lazy lately, I really want these things, just dont have the time or energy to do it. Thats pretty sad.
usually too high and angle or too much pressure is the culprit- and you may have to reprofile a bit to fix it. on some convex edges (mostly me, it seems) you have to take a scandi approach and work the whole bevel - but it's worth it.
In the field I usually can get by with even a carboard strop, but there's no reason you can't use a stone. You just have to vary your angles as you go- it's a light technique, not too hard to learn.
