Convoy C8+ flashlight is the successor of Convoy C8, utilises a XPL-HI LED with 2800 mA output from single 18650 battery and has many improvements on host/body design. The newer version has full of fins on the head for better heat dissipation, aggressive knurlings for better grip, and new U-shape design on its tail cap for easier clicky operation.
Main Parameters:
Light Source: Cree XPL HI beads
Max Output: 1100 lumens
Range: 150 meters
Power Source: 1 x 18650
Peak Beam Power: 11W
Waterproof Rate: IPX-8
Product Features:
● Utilize XPL HI LED that with 1100 lumens high performance.
● Powered by 1pcs 18650 lithium battery (protected or unprotected), easily buy and recharge.
● Constructed from aerospace grade aluminum alloy with HAIII military grade hard-anodized finish.
● Deep diamond knurling design body ensures the light is easy-gripped.
● Specially made high reflectivity smoothreflector.
● Expert level design with 12 groups of 55 modes dimming for your daily use and research needs.
● U shape tail with self-protection defense tactical function.
● Reverse polarity protection prevents damage from incorrectly inserted batteries.
● Eight lighting modes, 0.1 percent brightness, 1 percent brightness, 10 percent brightness, 35 percent brightness, 100 percent brightness, strobe, biking and battery-check, so many brightness options are convenient for us.
● Memory function mode, when the flashlight is turned on for more than 3 seconds, the power mode may become erratic. Turn it off, and turn it off, still the original mode. If less than 3 seconds, turn it off and then turn it on, then go to the next mode.
● Low voltage protection function, when the voltage of the battery is 2.9-3.1V, the flashlight flashes 2 times / sec with low brightness. This is a low voltage warning.
● Waterproof in accordance with IPX-8 (2 meters submersible).
● Tail stand capability.
Come to buy it on GearVita with a favorable price of $19.99: https://gearvita.com/convoy-c8-led-flashlight-cree-xpl-hi-1100-lumens.html
Related products:
convoy s10
convoy s2+
Main Parameters:
Range: 150 meters
Product Features:
Related products:
convoy s10
convoy s2+
