I purchased a new 2x72x10 grinder from Norm about a month ago. Bolted it down to an 5/8"x18"x20" steel plate, bolted to my bench and extending over the front edge by 6". Cut a notch in the contact wheel side of the base plate for clearance and fabricated a steel brace under the extended portion. Mounted my 1.5 hp motor on a hinge with a 38" v-belt and 3-step pulleys. Man, this thing is ROCK SOLID.
When I first set it up, it had a horrific vibration. I noticed that the 3-step pulley on the drive shaft of the grinder really wobbled. I put a dial indicator on the shaft and it had 10/1000 runout. Called Norm, he suggested a stop on the motor plate to regulate the amount of tension and shipped me a new shaft immediately! I replaced the shaft, that helped a little. I built a stop for the motor plate, that helped even more. Still too much vibration to suit me. I went to the auto parts store and got the cheapest v-belt I could get, took off the high dollar lawn mower belt and that REALLY helped. It seems that the lawn mower belt is too stiff and magnifies even the smallest vibration or run out.
I have too say that Norm Coote has been excellent to me!!! In communication from the day I sent the money and all the way thru my vibration dilemna. It really is a nice machine for the amount of money that it costs!!
