Hello community.
I'm Allen and I have a question or two about corby bolts. I'v read that using two different drill bits wont exactly work because when you drill the outside hole it might not be centered. So what tool do i need to use to drill with? The hardware store told me they had a countersink bit that would do it, but they weren't sure what the bigger part of the bit size was, "it should be close" does not make me feel confident that it will work.
Also if i can find a countersink bit, do they make them where the bigger part will drill flat, instead of a bevel.I would assume a flat rivet head resting on a beveled hole would not be very strong.
Or am I way off and looking at the wrong bits?
Thanks for the help.
Allen
Allen
