Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
When I have needed to make a quick counterbore for a recessed hole in a scale or other project, I chuck the desired size stub length drill bit in a cordless drill and grind the step down on a disc grinder or against a coarse diamond stone. It can be done on a lathe or drill press, too.
Try to get the step even and at a perfect right angle. The pilot should be the exact size of the bolt shank. Once done, I grind the newly created shoulder edge at an angle with a small diamond disc in a flex shaft/Dremel tool/die grinder. This creates a sharp cutting edge to make clean seats. You might say the cutting part is sort of like a tiny Forstner bit.
To use this counterbore, I first drill the pilot hole for the shank and then use the counterbore to cut the seat.
You can do a similar counterbore by turning down a spade drill, too. You have to sharpen the new cutting edges you created. Be sure to leave the spur tip or it won't bore smooth holes.
