- Jan 10, 2015
Yes....Carefully. Cut a notch in each end of the screw/bolt set. Heat gently with soldering iron......turn out old screws,
then re-countersink a little deeper. Shorten male and female ends of new screw, and check depth....then replace in scales.
I put mine at about .190" and mark that on the top and bottom with a line on the scale to insure not to go to deep.
I had a problem with a scale and was able to get the corby out with a screw extractor in my cordless impact. The screw extractor set is a few bucks at harbor freight.
When this happened to me I drilled out the pin with a 3/16th and then replaced the bolt with a 1/4 inch nickel silver pin. It looked perfect so I drilled out the other bolt also and pinned it. I used Loveless bolts after that for a while until I had more confidence but now use Corbys... but measure a bit more first. Larry Lehman
I set my counterbore to leave about 1/16" in the bottom of every knife I make. Then when I'm mocking it up and my corbys don't seat all the way I shorten them on the grinder.
Hey Matt, not sure what you mean about not seating all the way, and what part do you shorten?
Kevin is correct. If the tang is too thin then the bolts are tight before they seat in the hole. That's when I shorten both ends so they will pull up tight.
This forum are it's members are worth their weight in gold.![]()
