Kevin the grey said:
Codger ? What about bull rushes ? Those long thin leaves look like they might be good cordage . How would I use/prepare them ? In case bull rushes are called something else other places it is the long reed/canes with the hot dog shaped brown seed pods on top of them . Frequently seen in marshy ditches and swamps .
You have underscored the problem with common names for plants. The plant you are describing is usually called Cattail (Typha spp.) (long leaves and hot dog shaped brown seed pods). Bulrush on the other hand, generally have short leaves and no hot dog shaped seed pod, and belong to the Scirpus genus.
The leaves can be used for cordage (although not some of the stronger stuff) by gathering the leaves splitting them in narrow lengths, letting them dry, and then when ready to use, spray them with a hose, etc., shake off the excess water and store them between
damp towels, etc., overnight and they will be ready to use. You can also just take dry ones, soak them, and then use them, but my experience is they are not as strong. The former technique is also used for preparing Cattail leaves for basket making (without the splitting, though, although you could split them for finer applications.) Also if you want large diameter cordage, you don't need to split the leaves.
Twined Cattail basket on left
Small Cattail basket with lid
Cattail hat
Doc
