- Apr 20, 2013
I'm gonna chime in here and say that a polished knife (at the very least worked up to 600-800 grit) will stave off rust better than just a plain stripped one. Can't really change the chemistry of 1095CV, but you can make it so there are less places for moisture to hide and for rust to get a foothold. You'll still get patina (food and plant acids will see to that) but rust should be less prone to happen if you take decent care of your knives (and I know you do). For everyday care I find that mineral oil, or something like Howard Butcher Block Conditioner (mineral oil, beeswax & carnauba wax) works fine. Totally food safe, you can get it (at least the plain mineral oil) anywhere and if you have an empty eyedrops bottle you can carry a long lasting supply in a very small package. Granted, it doesn't stay on very long...but it's dead simple to obtain and use, doesn't smell bad, and is a good preventative if used daily. Also doesn't go rancid like most vegetable oils.
But polish - yeah, polish. It's worth it if you're only going to do it to a couple blades, but you also have to make sure you're thorough and work your way up through the grits so that you don't leave any valleys (scratches) deep enough for rust to hide. That's my take, anyway - my 11 that I modified got a satin polish and has patina'd a bit since then....but I've not had a problem with rust as I have had on some of my other Beckers - and my backyard is a salt water estuary; lotsa stuff here seems to spontaneously corrode.
