Suddenly a part of the shield was protruding from the handle. Stays put fairly well if I push it back. Should I glue it? What glue in that case?
Thanks, I thought you only saw the link to press first.The pics show up. Agree with Mike, superglue it.
Damp the q tip with glue?If you reglue be sure to scuff the back of the shield with sandpaper and scratch the bottom of the inlet for the shield with the tip of a blade. Clean with alcohol and dry it then take a damp q tip and just barely dampen the inlet before regluing. All that work will help it adhere better and stay in place longer, I have one I did this way 7 years ago and it's still holding strong.
All good advice.If you reglue be sure to scuff the back of the shield with sandpaper and scratch the bottom of the inlet for the shield with the tip of a blade. Clean with alcohol and dry it then take a damp q tip and just barely dampen the inlet before regluing. All that work will help it adhere better and stay in place longer, I have one I did this way 7 years ago and it's still holding strong.
Can I clean with acetone? Wild TurkeyIf you reglue be sure to scuff the back of the shield with sandpaper and scratch the bottom of the inlet for the shield with the tip of a blade. Clean with alcohol and dry it then take a damp q tip and just barely dampen the inlet before regluing. All that work will help it adhere better and stay in place longer, I have one I did this way 7 years ago and it's still holding strong.
Can I clean with acetone? Wild TurkeyHaven't got alcohol for cleaning. Koskenkorva vodka?
Acetone will attack plastics. I wouldn't use brake cleaner, either.Can I clean with acetone? Wild TurkeyHaven't got alcohol for cleaning. Koskenkorva vodka?
