- Apr 3, 2011
What do you guys do with your's when it goes dull? And why is mine going dull so fast? Barely made one sink in a ti scale and it's dull. I've got the interstate set from mcmaster carr I believe.
Thanks for trying to help me man! ... is what I ordered I believe. Would there be a different kind that would be easier to sharpen or better for titanium?
I've never tried those zero flutes, and the single flute I used in my drill press seemed like it just wanted to chatter all day long. I've had best luck with 6 flute countersinks.
I've also seen guys use step drills with some degree of success, depending on thickness of material and hole diameters...
Thanks guys, looking up the Cratex bit now...
Matthew, that's a great idea! Thanks!
Yeah, the ones I got were specifically because they dealt the best w/ sloppy spindles, and I'm using a cheap ryobi drill press =) so the 6 flute would work well?
Seems to work best for me given the options. Depending on spindle slop/runout you may still get a little chatter. Just follow up with Matthew's suggestion and you should be fine.
Try not to overheat, and use a little bit of cutting oil to clear chips and it should last a good while.
A coutersink followed with a Cratex polishing bit would do it.
I have in the past, but normally I'll just buy a new one.
That said, they normally last me a pretty long time. Just don't try them on hardened steel.![]()
I have an old box of Cratex bits I got with a machine deal. Let me see what's on the shelf in the shop after work. I'll PM you if I think something might work. These cratex bits screw onto a mandrel, like a buffing wheel does.
