oscar zeta
- Apr 27, 2001
I've had Sebenzas before but have always had to sell them off for financial reasons when I was younger and probably shouldn't have bought them in the first place. Fast forward several years and I'm finally able to purchase and actually enjoy a couple of Sebenzas.
So I just got these two over the past 1-2 weeks. They're everything I remembered and expected as far as fit, finish and overall utility. I'm using these as alternating EDCs, depending on the occasion, how I'm dressed, etc.
I do have a couple of questions on the 25 and hopefully someone can help me out. I (perhaps foolishly) disassembled it a few days after I received it and I'm having trouble with the pivot. It doesn't seem to have as much of an effect on the looseness of the blade opening as I would think it should. Also, when I have it set to where I want it, I can push the pivot pins back and forth through the hole just slightly when the knife is closed. Is that normal? I can tighten it down all the way but then it's just a bit tighter than I would like it. When I totally remove the front pivot, the blade still opens up the same, no real difference.
Should I be adjusting both sides of the pivot?
Should the knife be opening more smoothly when I loosen the pivot?
When I took it apart, I accidentally bent the back washer, but I believe I straightened it just fine. And I'm pretty sure it hasn't affected performance. I think it was like this even before I took it apart.
Thanks for any help! I've been reading and searching through here and couldn't find a similar topic.
