- Apr 19, 2006
Gollnick said:Start with clean light, keep it clean the whole way, do as little to it as possible, and you will have a good picture. Every time you try and cut a corner, every time you try for a free lunch, it will degrade the quality of your image.
exactly. the lens matters. a million megapixels and the best sensor on earth mean nothing if the light hitting it sucks. if you don't expect to use flash in anything but broad daylight, check the maximum aperture on the lens. the smaller the number the better. if you can maintain a constant f/2.8 throughout the zoom range, you're going to have lots more low-light versatility. if the number is like f/5.6 you're going to be relying on the light sensitivity performance of the sensor, which will give you a crap image on a point-and-shoot. another thing is to make sure it has an optical viewfinder in addition to the LCD. you might not think it's a big deal but it goes a long way towards battery conservation and it makes it a whole lot easier to shoot in bright light.
you wouldn't expect a good knife from a box labeled '$5 Sale' so don't expect free lunch from camera manufacturers. resist the urge to be cheap and do things right the first time. just because something is a deal doesn't mean you should jump on it blindly. determine your needs and carefully select the correct tool for the job. if you can't afford to put money into a quality digital camera, pro-level film cameras are available for just a few hundred bucks.
