- Dec 2, 2013
I bought a piece of O1 for my second knife ever, because Jantz (I think that's where I ordered it from) said it was an easy steel to heat treat at home. Then found out it should soak for 10-20 min., which ain't happening with my weed burner. So I have been doing a bunch of searching online, and it looks like I can get the job done, if not ideal, with a simple heat and quench.
I intend to use canola oil for my quenching media, because I have some I used for my first knife, but I see that it should be heated up rather than just used at room temp? Also, I plan to temper at say 360º F. for an hour then air cool.
Now for my questions...
1. Why heat the quenching oil before quenching, and how does one determine what temp it should be heated to?
2. Does my temper temp sound about right? I was thinking 375º but thought I'd drop it a touch to make up for the less than perfect heat treating without a soak time. (shooting for somewhere around a 61-62 Rc)
3. I see triple quenched and triple tempered advertised on custom knives sometimes. Is there a benefit to tempering it more than once?
4. I know I can't hold the O1 in the 50º window that it should be soaked at for 15 min, but would there be any benefit to trying to keep it in the neighborhood of somewhere beyond magnetic for a couple minutes or so before quenching it?
5. The knife is 1/8" x 1-1/4" x 7" (2-5/8" blade) I was intending to just quench the blade and leave the spine out of the oil, but would I be better off just dunking the whole thing or not?
Thanks for your time and help!!!
