Until you need to memorize them (or want to for some reason), the easiest way to figure out which one you already have, is to go to either tomarskabars.com (a BF sponsor here) or kabar.com and look them up and compare what you have with the pictures/descriptions on the sites.
There are 4 traditional leather stacked handle versions and 4 all black Kraton handled versions.
The leather (L) handle versions are clip point only, plain edge (P) or combo (partially serrated - S) and marked either USMC or USA (C or A)
LPC is 1250
LPA is 1251
LSC is 1252
LSA is 1261
The Kraton (K) handled versions are marked USA only, come with either a tanto (T) or clip (C) point, and either a P or an S edge.
KTP is 1254
KTS is 1255
KCP is 1256
KCS is 1257
All eight (8) of these model numbers come with leather sheaths, either tan for the Ls or black for the Ks.
By changing out the leather sheaths for the black plastic ones, the 4 K knives' model numbers change (as far as the factory inventory control procedures and box labels are concerned).
The 2 clip points become:
KCP is 1258
KCS is 1259
The 2 tanto points become:
KTP is 5054
KTS is 5055
On the sheaths, I really like the plastic sheath for these knives (at least when carrying for use in the barns and such around the farm). Some folks don't like the plastic sheaths, each for their own reason(s).
First, they are waterproof. No real maintenance required other than to let dry after getting wet or being washed.
Second, the sheath is ambidextrous in accepting the knives. If you put a lefty on the right, just pull out the knife and turn it around.
The sheath can be carried via
-a belt loop strap,
-a buckle-like fitting through which a 1" strap can be passed (say like a shoulder strap)
or
-by running straps/cords through the 4 slots (2 each side) and 8 para-cord sized holes (4 each side) along the edges of the sheath.
The sheaths also have 3 knife retention methods. If you loose a knife from one of these sheaths, you probably shouldn't be allowed to eat with anything sharper than a spoon.
The sheath has a "traditional" handle keeper strap, an ambidextrous, over-the-guard strap and a pair of little molded plastic "teeth" that engage over the guard when the knife is firmly seated in the sheath.
They look a kinda "tactical" or "tacti-lol" for city carry, so I usually use leather for going to town, but if I'm in a hurry, I just use which ever sheath they happen to be in. And around the farm under real working conditions? Who gives a rat's posterior about looks?
