I recieved a piece of ats-34 from a member on here (thanks again joesouth) and I decided now is a good time to try to build my first knife. I was going to order some 1084 but I am going to try the ats-34 first(why not
I am building the whole knife without using any power tools except for a drill.
My questions are:
the steel has a few small pits and is not 100% flat on the sides,
how do you guys get the steel flat and remove the pits?
do you do it after you cut out the shape of the knife?
I was thinking about cutting my knife out the just taping a piece of 80 grit sandpaper to my table and sanding until all the pits are out and its flat.
then filing the blade.
would this be a good way?
Also is there a size and shape a certain knife should be close to?
its will be my (adult) knife,
Drop point skinner, I was thinking about a 4 or 5 inch blade, not 100% sure on handle length, its 1 1/2 High.
Thanks for any help
My questions are:
Thanks for any help
