Acebeam EC50 Gen III flashlight is updated version base on early one, now equipped with a powerful CREE XHP70.2 LED and powered by 1 * 26650 rechargeable Li-ion battery, max output 3850 lumens beam throw 326 meters, compact size and lightweight is for convenient operation. Also redesigned massy bezel must be your super personal body guard in daily use to outdoor and professional use while a simple press on the side switch is all you need to select output.
The body of EC50 Gen III has been knurled with a diamond pattern to make longterm use less harmful to the skin on your hands. The vents on the sides of the head to make sure the LED and circuits don't overheat are fewer but wider. The strike bezel has also been given a larger form this time, giving it a bit more heft than previous versions. It is the brightest EDC flashlight integrates high performance and long standby time, adventurers and flashlight enthusiasts are very excited for the release of the Acebeam EC50 Gen III.
Main Parameters:
LED Type: CREE XHP70.2 LED with a lifetime of 50,000 hours
Power Source: 1 * 26650 battery
Maximum Output: 3850 lumens
Max Beam Throw: 326 meters
Max Runtime: 50 days
Peak Beam Intensity: 26500cd
Waterproof: Standard IPX-8 (2 meters)
Impact Resistant: 1.2 meters
Output Levels and Runtime:
Firefly: 1 lumen ( 50 days )
Low: 200lumens ( 14 hours )
Mid: 1000lumens ( 2.8 hours )
High: 1800lumens ( 1.2 hours )
Turbo: 3850lumens ( 2 mins + 1.1 hours )
Strobe: 1800lumens ( 2.2 hours )
Product Features:
● Latest CREE XHP70.2 LED with amazing 5000K tint.
● Max output is a staggering 3850 lumens with a beam distance of 326 meters.
● Aircraft-grade aluminum body structure.
● Ultra-clear tempered glass lens with anti-reflective coating.
● Premium type III hard-anodized anti-abrasive finish.
● Smooth reflector gives perfect beam and throw.
● Tactical diamond knurling makes longterm firm grip easy on the hands.
● Streamlined body design.
● Easy to use side switch interface.
● Intelligent circuit board design for maximum performance and long run time.
● Digitally regulated output maintains constant brightness.
● Over-heat protection to avoid high-temperature of the surface.
● Reverse polarity protection prevents damage from improperly inserted batteries.
● Low battery indicator will flash when voltage down to 3V.
● Micro USB chargeable, plug USB cable directly into light to charger.
● Waterproof to IPX8 standards.
With unstoppable power like that, this flashlight is perfect for just about anything that will come up in everyday use. Great for typical chores where you need a light or even late night navigation, the EC50 Gen III is the ultimate light utility for most users.
It is on sale at the GearVita at a cost of $114.99, but if you enter the coupon code "ABEC50", the price will drop to only $102.99. Otherwise, the coupon code is valid until Oct 20th: https://gearvita.com/acebeam-ec50-gen-iii-led-flashlight-3850-lumen.html
Related products:
https://gearvita.com/acebeam-ec65-4000lm-rechargeable-flashlight.html
https://gearvita.com/acebeam-k30-led-flashlight-5200lumens.html
Main Parameters:
Product Features:
Related products:
