delta 3v CPK field knife
Excellent condition , used once to feather stick , razor sharp factory edge
With Sagewood Gear leather sheath
black micarta scales
SOLD... PRICE DROP $SOLD shipped conus
PAYPAL ONLY
PM or email jjwebwebjj at g mail dot com
DO NOT POST IN THREAD
UNLESS “YOU WILL TAKE IT “ AT TERMS LISTED
The Field Knife was designed as a collaboration with Lorien Arnold. It is a well made, no frills, high performance utility knife. The steel is Crucible CPM 3V at HRC 61-62 with the fully optimized heat treat with very good edge retention and edge stability. You'll be surprised how sharp this gets and how well it holds an edge. If you have never used 3V this hard and thin, it is gonna blow your mind.
This steel with this heat treat will support a fine edge, so this was taken down to .015" before sharpening (though I'm leaving some additional meat in the tip now) and it was sharpened 18 degrees per side. This is relatively acute and it cuts well, but is very durable. They're also lightly hand ground after machining to give it a slight convex grind.
Some might consider this a tactical knife but the point is not reinforced and it is not shaped or balanced as a weapon. It's reasonably thin behind the edge. It is a hard working cutting tool, a big skinning knife and woods knife. There is a pry/scrape in the tang.
The handle is ergonomically designed for a standard forward, reverse, saber and pinch grips for an average to relatively large hand. The tang is internally skeletonized. The scales are 3D sculpted CNC machined. The blade is made of 3/16 3V with a heat treat that has been optimized to maximize edge stability in rough use. Despite being relatively thin it is durable. You can baton with it. You might damage the fine edge if you set your mind to it, but the knife itself is practically unbreakable.
A side effect of this heat treat is a higher percentage of free chromium, so although it is not stainless, it is nearly so.
Specs:
3V, tested 62 HRC, .188 thick at ricasso
This 3V is a fully optimized 3V for this hardness and application
Total length 9.75
Blade length 4.625
Weight 8.0 oz
Grippy 3D machined scales in micarta
Black oxide treated 18-8 stainless steel fasteners
PAYPAL ONLY
Specs:
Total length 9.75
Blade length 4.625
Weight 8.0 oz
