CPK HDFK 3V with sheath D-3V SOLD
Mike Pierson
Freedom is not Free
Feedback: +53 / =1 / -0
6B11E490-2067-45C8-BB5B-1458D225246A.jpeg 2721B80B-4FAE-4C18-A50A-1D712A8C5DCC.jpeg 885F61EB-BBD9-4C1C-848A-9BB0306A259C.jpeg D2BDBF2C-1834-4C64-8330-BACE5EECC427.jpeg 1- CPK HDFK with the BLACK MICARTA handles, DELTA 3V,
with kydex sheath & Tekloc.
Catch and release: I received this knife yesterday 10 July 2018
Selling only due to a new CPK purchase today... :)
PayPal -
Shipped by USPS Priority Mail.
Please post I will take it on thread.
No Trades.
Thank you & Thank you BladeForums!
0A4B4018-70C8-429B-855D-17BBA78F9DB9.jpeg 10167AF4-D8E7-4AD1-B750-434105157A3F.jpeg 438BCDB4-221A-4308-9971-95E2B721E665.jpeg
Price adjusted
Received this razor sharp 3 V CPK HDFK yesterday, must catch and release do to my knife addiction-
I bought a CPK 3V medium chopper today so this needs a home now, sadly as I will regret this...
Unbelivebly sharp, great balance.
As described by Nathan-
The Heavy Duty Field Knife was designed as a collaboration with Lorien Arnold. It is a well made, extremely durable, high performance large utility knife designed for comfortable extended rough use. The steel is Delta heat treat optimized Crucible CPM 3V at HRC 60-61 with very good edge retention and edge stability. You'll be surprised how sharp this gets and how well it holds an edge. If you have never used 3V like this, it is gonna blow your mind. If you have never handled an HDFK N.A.S.K. IT IS GOING TO BLOW YOUR MIND. This is pattern is one of our better efforts.
This steel does not need to be extremely thick to be nearly unbreakable, so this was taken down to.025" before sharpening and it was sharpened 20 degrees per side. It's a hard-use knife that cuts well.
They're hand ground after machining utilizing tooling and a process we developed to reproduce thecomplex bevel geometry found on a competition cutter with three world championships on it. We're developing that capability for another project but decided to include it on this new pattern. Itincorporates a very shallow S grind that is mostly flat, but convex at the shoulder and behind the edge and includes an approximate 100" hollow grind in the center of the grind.
Some might consider this a tactical knife but the point is not reinforced and it is not shaped or balanced as a weapon. It is a hard working cutting tool that could be carried into combat, a big skinning knife and a hard use woods knife.
This is our most developed hand grip yet. It supports multiple positions to reduce fatigue and accommodate multiple tasks including a pinch grip and choil grip at the balance point for detail work, a regular hammer grip and saber grip and also a rearward 3 1/2 finger grip that allows you some extra length that makes it a surprisingly effective chopper for its size. The full size handle has been thoroughly tested and designed to minimize hand and arm fatigue during extended use.
Unnecessary weight is removed where possible and the tang is internally skeletonized for a neutral balance. The scales are 3D sculpted CNC machined. The blade is made of .220" 3V with a heat treat that has been optimized for edge durability in rough use. You can baton and pry with it. You might damage the edge if you set your mind to it, but the knife itself is practically unbreakable.
A side effect of this heat treat is a higher percentage of free chromium, so although it is not stainless, it is nearly so.
Specs:
CPM 3V, Delta heat treat, tested 60-61 HRC, .220" thick at ricasso
Total length 11.825"
Blade length 6.5"”
Weight 12.8 oz
Grippy 3D machined scales in micarta and Terotuf.
Black oxide treated 18-8 stainless steel fasteners
The price includes a very nice Mashed Cat sheath with TecLok. This is not a small knife so if you'd prefer a dangler sheath rather than a TecLok add $15 to substitute for a dangler sheath.
(If you're putting it on or in your pack or carrying it horizontal you might prefer the TecLok but if you're planning to carry it vertically on your belt you might prefer a dangler)
My PayPal is ////////
Once PP GS funds are received will update post.
