Be careful about drawing conclusions from this. It is a single study and he begins by acknowledging his results differ from others who have examined the issue. He's working with one steel - A2 - and makes unsupported suggestions that results would also apply to other tool steels as well as stainless. He has only applied one of many possible 'toughness' tests.
Note also that in every case, the cryo'ed samples ended up harder and more wear resistant than the control by a good margin. This study focussed on wear resistance primarily, using the 440C ball, the diamond scratch and a surface hardness test converted to RHC.
If someone were to draw conclusions about cryo's effect on steel, I would suggest a more exhaustive review of the research as well as a review of manufacturers literature and 'pers. comm.' from expert sources like this forum.
Mr Stenoien rightly poses the question that should have been examined if this study related to toughness.
Look at the crucible data sheet for A2. That charpy toughness curve is not exactly typical of other steels we use.
Rob!
