- Jun 29, 1999
That's the most fragile part of the blade, so no surprise. Just sharpen it.
Sorry to hear that, but at least you got it back to factory. Is that in 20CV or S35VN?I dropped my ZT 0562 to the hard wood floor. The knife was closed but the edge bevel near the tip sheared off. Only way j can describe it. Took a little elbow grease on the diamond stone but I got it back close to factory I think.
Thanks for your great input. I'm learning a lot here. It makes sense that the factory edges are a little fatigued after the grinding process. Once it's ready for a resharpening I think I can get the folded steel/rolling out.This can happen. Countertops, plates, etc. can be very hard. It could have gotten bumped casually, went through the box just right at a seam, etc. Trace the line of the bend and realize just how thin a cross section of blade that is. Also consider that the steel along factory edges can sometimes be a little fatigued by the grinding process and not representative of the true quality you'll get after putting a few fresh edges on it.
Once you've sharpened past that by hand, I'd expect your overall edge retention to improve here too.
That seems to be what everyone is saying. Thanks for your input.After a sharpen or two it will be just fine
A little off topic, but do you think a blade that is re-sharpened on a WorkSharp system won’t hold an edge as long as if it were sharpened on stones?TBH most of my new knives experience chipping or rolling, from S110V to 1095. I equate it to power tools being used at the factory. After a good session on stones the issue usually is allieviated.
It sort of reaffirms my preference to use a blade prior to going camping or on an adventure to address these issues.
That's a great question, and one I could not answer as I don't have one.A little off topic, but do you think a blade that is re-sharpened on a WorkSharp system won’t hold an edge as long as if it were sharpened on stones?
X 2!!Sorry to hear that. I feel your pain. Nice blade though.
Hmmm...thanks for the heads-up. I just got one of those. (birthday gift a couple of weeks ago.)OK, thanks for your input. I'll sharpen it up. The knife barely tapped the bottom of the pastry box, which is why I was so surprised that the tip dulled. It really took just the tiniest of taps. It's a Hogue Deka. Great knife, I recommend it. Just don't go cutting up any almond brittle.
It is unlikely if you keep the blade moving across the belt.A little off topic, but do you think a blade that is re-sharpened on a WorkSharp system won’t hold an edge as long as if it were sharpened on stones?
Thanks for your input--much appreciated. Chances are it tapped the counter underneath without me recognizing it at the time. Otherwise, how exactly would an overheated tip lead to rolling? Would this make the tip harder/softer? Just curious.Looks like an over heated tip from power factory sharpening or you hit the counter underneath and don’t know it.
A guy on Youtube actually did a cut test comparing two of the same knives sharpened to the same level (BESS tested), one on stones and another on the Ken Onion Grinder. The Work Sharp knife performed a little better, surprisingly. Small sample size, and the difference wasn't significant, but reassuring if you're using that system.A little off topic, but do you think a blade that is re-sharpened on a WorkSharp system won’t hold an edge as long as if it were sharpened on stones?
This is also part of why edge retention results tend to pick up with subsequent edges in controlled cut testing.
