I have been fiddling around with CPM 3-V and, having made few knives, I thought I should test one to verify the heat treat procedure. I chopped a few 16p nails of varying diameters, and the damage to the blade may be seen in the images below. I used Crucible's procedure up to the quench, which I performed (air quench) with to very thick steel plates, and then an hour in an alcohol/dry ice bath. I tempered for two hours at 400F, which gave me Rockwells in the 64-ish range, which I thought a bit high. So I performed the second temper at 450F, resulting in Rc's in the low 60s, about 61-ish ( I had calibrated the tester and it showed accurate within the test block tolerances). My question is, for those of you who use this steel, does the damage to the edge seem excessive, or about what you would expect? I observe no chipping or cracking, just a dented rolled edge. Also, would you keep the second temper at 400F?
Thanks for any input.
gene
gene
