Remember that cryo is only part of the heat treat ,it's not something you can add later. If you're HT'ing a complex steel and don't have the equipment for precise time and temperature you best send it to a commercial HTer to do it.
There are places that will take your money and freeze your blades after-the-fact and they will tell you it is helping. And in reality it is making some measureable changes, but they don't add up to much. To my knowledge, after-the-fact cryo applied to a finished blade has never had any noticeable effect in cutlery.
Yeah, I know. I remember the graphs - preheat, heat, quench, temper, cryo, temper, temper as a single process.
But while sub-zero treatment is doable even at home, cryo is not. So I wonder if it is worth worrying about, or it is better to leave it for the future time, and now concentrate on other elements of HT.
We do a sub zero quench as part of the quench on certain steels..Its a dry ice and acetone bath that reachs about -104°..Its main purpose is to reduce RA, that's why we use it..RA reduction takes a temp of about -95° to work if Im not mistaken. Im looking for a dewar because I have access to LN but I haven't ran across the right one yet(i.e cheap enough) We buy dry ice forabout .99 cents per pound close to home. Its not expensive at all.
Butch, for people that who haven't looked into these things, we should probably mentioned that the different in evaporation rate on a 20 liter dewar mean that the "big mouth" one will only hold the LN for 2 months as apposed to 4, right?international cryogenics i thinkm is where i got my brand new 20l with a big mouth (wanted it for taller kitchen knives) disadvantage of big mouth is faster evaportion. i make sure to have a batch ready to HT then go get itfilled so i can max out blades per fill. there are a few places that i can get my tank filled and cost is not too hateful
