CPM 3V Oregonto kwaiken 4"
BenR.T.
Tanto grinder & High performance blade peddler
Moderator
Feedback: +43 / =0 / -0
Up for grabs is one of my Oregonto kwaikens of the 4" variation. This smaller version is easy to carry IWB, and still offers plenty of blade length for most any task. The blade steel as with most of my knives is CPM 3V. My custom high performance Heat treat (including liquid nitrogen cryo) for these provides improved edge retention and corrosion resistance over the industry HT for 3V. These are designed as a hard use knife.
The handle is soaked in West systems G/flex epoxy, is rock solid and very durable.
The Harstfield style sheath is Aluminum, wrapped in shark skin and lined with kevlar. The "sageo" adds grip when tucked in your belt, and also extends to act as a static cord.
I have been carrying and using a tanto style pocket knife for over ten years straight. When I say "tanto" I am really referring to the grind style as that is what it is generally know as here. The utility nature of the tanto blade shape I think is underrated and often misunderstood. The angled front edge works awesome for scraping, much like a chisel. And the secondary point where the bevels meet means the blade cuts deeply on a pull cut or stab. The grind also reinforces the tip for piercing.
Here are the specs.
OAL - 8"
Blade - 4" chisel ground
Steel - .280" CPM 3v with proper HT done by myself including LN cryo. My Custom HT benefits not only fine edge stability but also increases corrosion resistance to near stainless levels.
Handle - Black tsuka ito with hemp underwrap.
Sheath - Hartsfield style aluminum sheath with shark skin overwrap and kevlar lining.
Price - SOLD
Paypal or postal money order preferred
Mind tricks do not work on me, only money. : )
