james terrio
Sharpest Knife in the Light Socket
- Apr 15, 2010
Short answer... after some testing and research, I sold off my stock of CPM-D2 and kept/bought more CPM-3V. 3V wins hands-down in every way.
Long answer... The corrosion-resistance is not noticeably different, in my experience. Neither will just rust overnight; both may get some pits and spots... nothing that detracts from the knife's usefullness. Google "passivating" for more info on how to get the most out of either alloy in that regard, or pm me and I'll forward you the info I have.
Polishing... I have no idea why so many people insist on HT'ing high-alloy, wear-resistant steels at 220 grit and then bitch about how hard they are to polish afterwards. Polish before HT and clean it up later. You CAN get a very fine finish on 3V this way, as long as you prevent heavy oxidizing/scale during austenizing. (tool-wrap, vacuum-furnace, etc.)
I'm currently working on a couple projects in Elmax, and the corrosion-resistance is absolutely outstanding. It remains to be seen if Elmax compares to 3V for toughness, they aren't HT'ed yet.
True. Also, 3V is tough enough to support a very thin, keen edge, which means when it does get dull, you don't have to slave away and grind off a bunch of steel to get it sharp again. Win-win!
Same here :thumbup:
You can buy little credit card-sized diamond stones, so field sharpening of even the high-V steels need not be an issue anymore.
If I knew I would be carrying a knife into critical situations, 3v would be my first choice.
Same here :thumbup:
