Prior to my question I will fully acknowledge that D2 has a whole lot of weather working against it in Florida. I'm sure the daily thunderstorms, recent 100°F days, constant 70% humidity, and my sweaty self are not helping the situation.
I already knew from reading the Forum and the little card included with the D2 Para that rust could be a problem. I have a D2 (coated) Griptilian and I've never had a rust problem with it in all the years I've had/carried it. The coating on my Grip is worn off in spots and I figured because it never rusted on those spots or on the cutting edge that the Para would be fine with minor maintenance. I was dead wrong. I have been making sure to wipe down the blade with gun oil (Rem oil, CLP, or Hoppe's) and not leave it wet or sitting in the elements.
The first time I noticed some surface rust it was on the jimping on top of the blade and inside the Spyder hole. I grabbed some oil, a steel brush, and made quick work of that surface rust. I started wondering if any of that rust was there when I got the knife. I pulled up some images I took the day I received the Para to see if any rust was on the blade.
Sure enough I could see there was already some surface rust in the Spyder hole but not on the jimping. It was no biggie because it came right off and the knife was produced 02-09 and I got it 06-04-09. I figured that 4 months sitting there would be enough time for little bit of surface rust and it came right off. No big deal.
A week later I had the same thing happen again so out came the oil and brush. This time I took the blade out of the G-10 to make sure I got the whole blade 100% clean. I was oiling the blade between the surface rust showing up but I guess it didn't help much if any at all.
Today I saw there was some pretty good surface rust the side of the blade at a spot that's under the G-10 so I had to get out the Torx set and go at it. This time there was some light pitting left on the surface of the blade. Not good!
So in less than a month I've taken the knife apart twice and had surface rust a few times between cleanings. I need to figure out some way to make this stop. I would hate to put this knife in my safe because I LOVE this blade. I use all the knives I buy and I don't want to have to watch the blade like its a 3 year old child.
Solutions...
1. Oil the blade every day (not very practical)
2. Retire my month old knife (heck no!)
3. Figure out some kind of clear coat I can put over the blade
4. Tuf Cloth? I've never used it so I dont know how well it work's. Will it be better than using oil? can I get them at Home Depot or another local store?
5. Tell me why I'm stupid and what I should do.
Please help me!!!!!!
Solutions...
