- Mar 1, 2010
Chris "Anagarika";16565087 said:Jason, Chuck,
I don't get it.
For same final apex bevel, say 12° per side. On thicker blade (primary grind) this results in wide bevel, say 0.4" before it transition to the primary grind. At this point, the shoulder thickness is say 0.03". If the primary is thinned down so this bevel now is only 0.1" wide, the thickness right behind the new shoulder is same as old bevel when bevel width is 0.4". However, the stock (now new primary grind) at 0.4" from apex is thinner (assuming 0.02") as it's now the new primary grind after being thinned down.
Why it is now better handling the chipping by lateral forces with less material at say, 0.4" from apex?
Chris, I have no idea but I would consider that a 12dps bevel is still on the saner side. I was talking about taking down 3mm thick stock to less than 10dps bevels. I find that I like the performance of knives that are made from thinner blade stock with less acute bevels than with thicker knives taken down to very thin bevels. I have a locally made 52100 knife that's around 2 mm thick and I really like how I can use it for all around tasks including wood working and still zips through thick media like cardboard. I can keep the bevel angle of this knife to around 13-14dps and it'll still work better for me than say a 3mm knife taken to lower angles.
That however is just my preference. It's probably a YMMV thing.
