John, Let us know how the blade performs long term ---this is interesting. Did you do a cryo cycle on it ? I have found S30V to be very forgiving and it is hard to blow the grains on this one. The other day I was heat treating and working on another project at the same time and forgot I had a blade in the furnace. This one was S90V and it got soaked for 4 hours at 2150. I figured that one is scrap --and it is-- as far as a blade to sell. So I decided to do a little testing with it. I clamped the tang in a vice and hit the blade a pretty good whack with a hammer. I expected it to break but it just went boing. I then ground some off to see if I could see any unusal grain structure, again it looked normal. I did a hardness test and it was RC 62, So far so good so I put it in the LN2 overnight and did a temper at 400. I came down to 60, just like you would expect for a normal heat treat. I will finish it into a useable knife and give it some more testing. Again I can't sell it but can maybe gain some more information on this class steel. After this radical soak it still seems to be just as tough and hard as a normal heat treat. It amazed me.. PHIL
