nozh2002
BANNED
- Jun 9, 2003
I got my CPM S90V knives done. It is accidently heat treated as CPM S30V, but I was assured that it should not make much impact on blade properties because process is similar. It is tested - 59.5 HRC with 60~61 on the edge because I grinded it to thin and it cooled off faster then other perts of the blade. I start sharpening it and testing on my thread-test-installation.
After Medium rods it shows results similar to what I had for Buck Vangard, but then after Fine Rods I found degradation - Fine Rods did not show same results as on Vangard. I try resharpen it several times and have same results all the nime - Fine rods increase reading to 30 points.
It turns out that Vanadium Carbides which CPM S90V has a lot (3 times then S30V) are harder then Aluminium Oxide, as a result CPM S90V damage Sharpmaker Ceramics and Ceramics damage blade - wearing out steel so vanadium Carbides falling out of edge.
I am wondering what Edge Pro Stones have in base - diamond and Silicon Carbides should make job done. Also what japanese wetstones made of (King and Polar Bear)?
Thanks, Vassili.
Thanks, Vassili.
