ok some im going to try and play around with both of these. my questions comes to the ht foil. i was going to get some foil from the tmickly fella. how tight do u guys wrap the foil? do u roll it up tight on the blade or do u make it more like a big envelope and put blade in middle and then seal shut? Also of these 2 steels i desire to make a knife that i can carry into the back country on elk bowhunts and not have to worry about sharpening them. at most i would only want to carry a credit card backed with maybe 220 sandpaper for touch ups. my reason for this is space is limited and any weight i can excluded the better. sounds like both these steels will do this if the ht is right. also i dont have plates to do a plate quench so from what i gather through the search function is a fan on high in front of blade to cool is acceptable. And finally i usually grind my bevels rough in on belt sander then file work it flat and square up my ricasso, am i going to have any problems with these steels pre ht with doing hand file work? thanks
