I'm fascinated with Dozier's heat treat--probably because of a mixture of being fascinated with anything that's "secret" and that I love his design sense. I just found this thread and wanted to add two observations from the recent youtube video in his shop (
http://www.youtube.com/watch?v=YGGwQnDXExM&feature=plcp). First, Dozier heat treats using a pre-heated oven. He's adding the knife at what looks like between 1000 and 1400 degrees (I'm guessing this based on the glow of the oven compared to my own Evenheat at known temperatures). There's a data sheet from one of the steel manufacturers suggesting something similar for D2--I don't remember which manufacturer recommends using a pre-hot oven, but they were the only one out of 4 or 5 that did so. Secondly, the post-heat treat blade shown in the video is very dark. When I've heat treated D2 (1850, 45 min, plate quench, 2x 2 hrs at 450), it doesn't color nearly as much as the almost black-purple blade that they ended up with. It looks much closer to the post-heat treat knives that were tempered at 900 degrees. This causes me to suspect that Dozier is in fact tempering at the 2nd hump. Nathan, you mentioned 'non-benefits' of tempering D2 in that range. What have you found them to be?
