- Dec 24, 2014
So in another thread I mention I had some Cpm154 laying around that I may finally make something from. And from doing a little searching I found its not that bad to have the prof. heat treated. So I may make the swap from 1084 to stainless to get some better blades. Now I have a few questions.
Heat treating 1084 at home I've been able to get away with grinding down to .01 before heat treat with no warping issues whatsoever. Now how far should I go down to with this stainless, before I send it out? I've heard of .03-.04 but, I don't like to do a lot of post HT grinding. But if its needed then, it will have to be done.
Also, the differences between CPM154 and 154cm I hear isn't HUGE, but the CPM154 is made with slightly better quality. Is this noticeably different in a blade? Aldos seems to have 154Cm in stock a lot compared to CPM.
And last, for these stainless steels, and others I guess also, is cryo treatment necessary? Or is it just another perk? I guess I should ask is it worth the extra $4-$6 a blade? I'm already assuming everyone will say yes...
I just want to get this all cleared up before I go ahead and order 5 feet of stainless.
