Nullack, normalizing is taking a material above it's transformation temp and letting it air cool. Non-air hardening materials result in a usable structure that is not hardened. Air hardening grades harden. It may be simpler to say you can't technically normalize an air hardening grade due to the wrong structure issue. I agree with Larrin that decarb and carburizing are not an issue, that is unless they show up during heat treatment. 3V will behave like any other tool steel and you need to address these issues if they show up.
Compressive strength was mentioned. Compressive strength is directly proportional to hardness (that's what a Rockwell test measures) and is about 5-10% higher than tensile. Metallurical data on high end steels like stainless and tool steels is very limited. You will always have some subjective input because of that. It's general, but the basics of all steels are usually pretty close if compared to the right group of alloys. The key is to not over analyze the small stuff. Steels somewhat simple and the properties, even though variable, are somewhat predictable.
