thanks oldphysics, i am a maker and have an analysis of infi, which is quite similar to the A8mod i use on some big blades. The 3v should be harder to sharpen with the vanadium so high, but should also stay sharp longer and being powder steel should have higher toughness for a given hardness and carbide content (though 3v will have a higher carbide content, infi is pretty low on carbon)
When i see 3v not performing better than just about anything i am suspicious of the heat treat
were the edge angles and thicknesses similar on the knives? Busse edges are thick compared to most of mine, significant effect on edge holding
i don't get to use search, but google helped me find some old stuff here on the forums...3v has had a very poor reputation, but the "secret and magical" heat treatments may be a major factor. many of the edge failures had 15 degrees per side edges, aren't busses a bit steeper?
Has anyone used it heat treated by paul bos?
has anyone tried S7 versus infi?
The S7 Busse uses is standard S7. He calls it SR-77 because of his heat treat. The knives are by Scrapyard Knives.
I haven't. I beleive Jerry Hossom has made many knives out of 3V and had many of them heat treated by Paul Bos and had very good reported results.Has anyone used it heat treated by paul bos?
I've had great results with both. I've only gotten INFI from Busse knives (obviously), and have only used 3V with Fehrman knives. I think 3V holds it's edge longer for cutting, I haven't yet been able to test the 2 for chopping. Using DMT diamond hones and ceramic stones, they are both easy to sharpen to me.
